Sponsored by: Innova
Help with Alpine nav unit please
Old May 9, 2010 | 04:51 PM
vetteracerx's Avatar
vetteracerx
Default Help with Alpine nav unit please
I have a IVA-W203 and the NVE-P1 in a 2001 ZO6. I have had this installed for around a year with no issues. Yesterday the nav function quit working. Navigation no longer shows up as a source. I have tried to reset both units with no luck. I also dont see a led lit on thenav units left side. Any ideas? Thanks
Old May 9, 2010 | 05:36 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
did you have the battery on a tender? I had this happen one time with my Kenwood after the battery went dead. Once i fully charged the battery the unit came back on.
Old May 9, 2010 | 05:54 PM
vetteracerx
I did have a tender on it all winter. When I tried to start the car it was totally dead. The redtop would not take a charge anymore. it was 3 years old. When I took it out it was real hot. Must have had a short in it. Would that have killed my nav unit? Thanks
Old May 9, 2010 | 06:56 PM
0Double D Mods
Former Vendor
you should be ok with a new battery or if the old one charges. Doesnt the Alpine have a seperate NAv unit anyways?
Old May 9, 2010 | 07:09 PM
vetteracerx
The alpine does have a seperate nav unit. it docks in the head unit. I put a new battery in the car same problem.
Old May 9, 2010 | 07:13 PM
0Double D Mods
Former Vendor
does the radio work meaning all other features?
Old May 9, 2010 | 07:37 PM
vetteracerx
yes its fine. the nav unit just slides inside the head unit. to use it you select nav from the source menu
Old May 10, 2010 | 08:29 AM
Piston_Head's Avatar
Piston_Head
Had this happen once. I ejected the Nav unit and hit it's reset button. It re-booted and was good to go.
Later,
Brad
Old May 10, 2010 | 03:02 PM
vetteracerx
I called Alpine today. My nav unit is dead. they are going to warranty it for me. Thanks guys for the input.
To Help with Alpine nav unit please
