Sponsored by: Innova
C5 Sub box plans
Old May 16, 2010 | 11:23 PM
Mickman's Avatar
Mickman
Default C5 Sub box plans
In the C5 FAQ the link is dead for the plans for building a sub box for the C5.
Does anyone have a link for that? I would like to build my own box to fit in the space at the back middle of the trunk.
Any help is appreciated!
Old May 17, 2010 | 12:36 PM
RAAMaudio's Avatar
0RAAMaudio
Former Vendor
If you use Baltic Birch Plywood and mostly fiberglass you can save over half the weight, what I do, what I will be offering later on for the C5 (C6 is being done now, far less weight, superb quality, what these cars deserve
Plans really not needed this way either, just do it, how I learned
Rick
Old May 17, 2010 | 01:32 PM
markcz's Avatar
markcz
I had a pdf link somewhere, but can't find it
This one opens in word:
http://home.cmaaccess.com/~patsygarc...sure_Vette.doc
Old May 17, 2010 | 01:45 PM
KCvetteowner's Avatar
KCvetteowner
Rick
Will this be a flush mount?
Does your design increase the air space inside the box?
Old May 17, 2010 | 05:00 PM
RAAMaudio's Avatar
0RAAMaudio
Former Vendor
Yes, much more air space, more depth so flush mount is easy(as long as the right sub is used of course) less weight, etc.....
Not sure when we will get to this but not to far off, month or two probably.
IF, there is a really good low weight unit available let me know, I will not do one unless there is a need
Rick
Old May 17, 2010 | 05:07 PM
KCvetteowner
Rick
I think there is a need (for me!) Looking for something to install either 2 10" JL subs or one 12".
Old May 17, 2010 | 07:58 PM
RAAMaudio's Avatar
0RAAMaudio
Former Vendor
I can take care of you on much more musical subs if interested, lower cost most likely as well
Rick
Old May 18, 2010 | 11:49 AM
Mickman's Avatar
Mickman
Thanks for the replys guys!
Old May 18, 2010 | 10:12 PM
NVTHIS's Avatar
NVTHIS
From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
I just got through building a customer a stealth box out of baltic birch and you wouldn't believe the weight difference over MDF. For those looking to save on weight, this is a great alternative.
Old May 19, 2010 | 10:30 AM
RAAMaudio's Avatar
0RAAMaudio
Former Vendor
I believe I recommended he ask you to build it that way for him, thanks for doing so
Since there is so much more room and easy to fit I might not have my own enclosure if you are willing to make them for guys I send you, as long as it fits the IDQ10v3 at least
Not sure if we even need to use fiberglass on the C5 box which saves a ton of time and cost. A well done BB unit weight is low enough, etc...might not save any or enough to bother so it helps everyone save money and weight at the same time!
Give me a call if you wish or an email, PM, etc....
Rick@raamaudio.com
801-829-4997
Old May 19, 2010 | 11:51 PM
NVTHIS's Avatar
NVTHIS
Rick@raamaudio.com
801-829-4997
Yes, as a matter of fact you did. It helped my lungs a little, by not making all that dust that MDF creates, lol. The box turned out nicely and very lightweight. Unfortunately I forgot to get a weight, so maybe he can get one for us. It should fit the IDQ10v3 perfectly. I personally don't think the use of fiberglass would be needed on these type boxes. I also meant to get a picture, but that didn't happen either,lol.
Old May 20, 2010 | 01:32 AM
jnjmarshall's Avatar
jnjmarshall
I will weight it with and without the sub when it comes in the mail. Thanks again NVTHIS for building it. Also, Rick, thanks for all your help (and continued answering of my questions) as I begin the install of my complete audio overhaul in my C5.
Old May 20, 2010 | 11:09 AM
RAAMaudio's Avatar
0RAAMaudio
Former Vendor
Glad we can all work together on this There are tens of thousands of our great cars and many owners want upgraded audio systems. I firmly believe these cars deserve to have the lowest weight, high quality systems they can, If I can help some, others as well, more than enough to go around so we can all have some fun doing this fun business
Note: If any resonance issues you can use a drilled out(for lower weight) brace inside the box as needed. My TT car has a 2.2 cubic foot sealed enclosure, bottom is fiberglass molded to the floor that I hand hammered to a bowl shape to get the depth(steel floor of course) which stiffened it significantly thus resulting in thinner glass needed. The rest is BB, 3 different gauges, three layers right where the sub mounts so I can flush it in but beside it, over internal braces, I was able to go down to one layer due to the small unsupported surface areas. The sides, etc are all short so thin material was used there as well.
Then end result is an incredibly stiff enclosure that only weighs 20 lbs empty! This car hit 138.4 db on music for a 2 minute average with a single Arc 15 and 1kw amp beating all but one bass monster systems because they all blew up, blew fuses, speakers, caught fire, etc as only built to play a single note. My system did not clip, distort, etc just played though I have to admit it was a Bass Mechanic track
And yes, it is my TT car, it is also an audio comp car and when I get around to finishing the big turbo build it will see the track again but this time run with the system playing, I just like to do things others do not do. It weights 200 lbs less than stock with nearly a full interior, comp audio system, cage, big brakes, wheels, tires, etc........and I could put plates on it if I wanted to
Anyway, a bit off subject but wanted to let you know my dedication to low weight, high performance audio
Have a great day!
Rick
Old Jun 5, 2010 | 01:01 AM
bfb1963's Avatar
bfb1963
I had an '04 Z06. With the fixed roof coupe, you have a great opportunity. I put three 10's in a rectangular box at the front of the cargo bay. Very little side room was left, just enough to run wiring and push/pull fans for ventilation. It separated the cabin from the trunk area. This gave me unbelievable bass by reducing the cabin volume, and it reduced road noise from the rear tire wells.
Also, light weight mdf is available, but I think it flexes a tad more compared to regular mdf. Any sub should have internal bracing anyway, so i suspect light weight mdf is fine. Do not use nails only, especially if you are going to run sealed and high power. Use rabbets on the panels and screws (if using mdf, then use mdf-specific screws). Baltic birch is good stuff, but make sure it is the 13 ply, not the 7 ply.
If you don't want that setup and are going with two subs, then I recommend one sub in each corner. That is called corner loading and it is sonically advantageous and more efficient.
Old Jun 7, 2010 | 05:41 PM
jnjmarshall
I just weighed the birch sub-box without the sub in it. It is 11 1/2 lbs.
Old Jun 7, 2010 | 05:52 PM
RAAMaudio's Avatar
0RAAMaudio
Former Vendor
Not bad at all
I have not used MDF for over 10 years now, the only thing it is good for is large trim panels in 1/4" as not as prone to warp as plywood.
BUT, if you need that then use Alumalite instead, super stiff, will not warp, incredibly low in weight
Old Nov 16, 2014 | 06:55 PM
GTATIME's Avatar
GTATIME
Default Will this fit?!
I know this is an older thread but maybe someone can answer this.
Will the Alpine SWR-12D4 Type-R 12" fit in this box?
Thanks in advance
-Taylor
To C5 Sub box plans
Old Nov 16, 2014 | 09:33 PM
markcz's Avatar
markcz
Originally Posted by GTATIME
Will this fit?!
Nope, not the 12". The 10" would be close, but should definitely fit if you add a spacer ring on top.
Any shallow mount 12" sub should fit fine, but deep ones like that won't.
Old Nov 16, 2014 | 10:38 PM
GTATIME's Avatar
GTATIME
Thank you for the quick reply, so with the 10 inch and a spacer ring I should be good?
Old Nov 22, 2014 | 11:18 AM
markcz's Avatar
markcz
Most likely, yes. Fold up a cardboard box using the plans to see how much room there is for the sloped portion, then compare it to the sub specs. Just be sure to make up for the thickness of the wood compared to the cardboard.
