Sponsored by: Innova
C-5 Bose Speaker OUT
Old May 28, 2010 | 04:20 PM
Speedway1's Avatar
Speedway1
Default C-5 Bose Speaker OUT
My Driver side front speaker is out. Which goes out first in the Bose c-5s? The Speaker or the amp. Which should I change first? Would hate to buy an amp and it be the speaker. Could I use another speaker and connect to see if the amp is working??
Old May 30, 2010 | 03:12 PM
C5Luv'R's Avatar
C5Luv'R
To check your amp, I would remove the passenger side door speaker and install it in the driver's door. If it play OK, then your DS speaker is bad. If not, the amp is bad.
Best of luck!
