Sponsored by: Innova
C6 speaker mounting depth
Old Jun 2, 2010 | 08:51 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
Default C6 speaker mounting depth
Anyone know the max mounting depth on a c6. I know you can get over 3". Obviouslly the baffle will give me more depth, I need to know without a baffle figured in how deep I can go without hitting the window
Thanks much
Old Jun 3, 2010 | 12:25 PM
BeansWorld's Avatar
BeansWorld
Crutchfield posts the following mounting depth for my 2006:
Front speakers
Dash: 3-1/2"
Front Door: 3-1/2"
Far rear speakers
Mid Panel: 5-1/4"
Hope this helps,
Eugene
Old Jun 3, 2010 | 12:28 PM
BeansWorld's Avatar
BeansWorld
Actually, that may be a factory replacement size without modification. Sorry for the confusion.
Old Jun 3, 2010 | 07:51 PM
pentavolvo's Avatar
pentavolvo
anybuddy no actual mounting depth on a c6 i know its in excess of 3 inches, as well what the actual diameter or the opening for the woofer is
Old Jun 3, 2010 | 11:25 PM
CraigE's Avatar
CraigE
The big stock opening is 9 5/8".
I have Dyn MW 162 with mounting depth of 2 5/8" and they just clear the sled on the rail with a 1/4" baffle. So that would be 2 3/8".
I think that I allowed 1/4' clearance, which was my comfort level.
If the sled won't interfere you might be able to get another 3/4" to the glass.
I currently have a 1/2" baffle plus a 1/2 mounting ring for a total of 1" inboard, and no problems with excursion hitting the grill. However I wouldn't go much more than that.
If I had my door panels off (which is often) I would gladly provide more exact measurements.
Hope that helps .
Old Jun 4, 2010 | 12:40 PM
pentavolvo's Avatar
pentavolvo
so if i can clear the rail i can prly get away with 4" with proper baffle
Old Jun 4, 2010 | 12:55 PM
RAAMaudio's Avatar
0RAAMaudio
Former Vendor
what happened to my post from last night???
Anyway, I recently removed 3" depth as mounted on the back of the baffles, 9" Morels, did not hit anything, not sure if much room was left or not though.
Quite a bit of room until you hit the grill so more depth should be ok, on a thick baffle, mounted on the front of course. I do prefer to keep my speakers as wide apart as possible though for a wider sound stage.
Rick
Old Jun 25, 2010 | 08:16 PM
30MilesOffshore's Avatar
30MilesOffshore
pentavolvo, what did you end up with? Speaker depth? Baffle thickness? I'm looking to do some switching out myself in the next couple of months.
Old Jun 25, 2010 | 09:28 PM
pentavolvo's Avatar
pentavolvo
havent done it yet
Old Jun 27, 2010 | 05:09 PM
mhoglund's Avatar
mhoglund
Front speakers
Dash: 3-1/2"
Front Door: 3-1/2"
Far rear speakers
Mid Panel: 5-1/4"
Hope this helps,
Eugene
If one wanted to use a 3.5 in where the tweeter currently sits would the depth there also be 3.5 in?
Old Jun 27, 2010 | 05:14 PM
pentavolvo's Avatar
pentavolvo
Hmmm not sure quite how deep it is. But I do know 1 11/16 fits fine with room to spare
Old Jul 2, 2010 | 06:37 PM
CraigE's Avatar
CraigE
Just measured it. 2007 C6
From face of OEM fiberglass baffle;
2-7/8" to sled
3-1/8" to rail.
3-3/4" to glass.
Caution that is ZERO clearance !
To C6 speaker mounting depth
