Sponsored by: Innova
Replacing stock non-Bose system?
Old Mar 20, 2002 | 03:10 PM
novi408's Avatar
novi408
Default Replacing stock non-Bose system?
I bought a '94 Corvette last weekend :D and am going to need to replace the stock stereo in it (tape player doesn't work, can't hear at highway speeds with the top off, doesn't have CD/MP3 player). It is just the plain Delco AM/FM tape deck, not the Bose. I looked through this forum and saw a ton of posts on replacing the Bose, but none on replacing this base system. Is it going to be pretty much the same as the bose? I see that the rear speakers are 6x9s and should be pretty straightforward to replace, but I haven't checked on the fronts yet (4x6"?). Does anyone have a write up on how to do this? Is it pretty much a simple plug in operation if you get the adapter harness for the HU? Will I have to add the resistors to keep the SYS light from coming on since it has the base system? Thanks for any help.
Old Mar 21, 2002 | 11:59 PM
Dave84/76's Avatar
Dave84/76
Default Re: Replacing stock non-Bose system? (novi408)
6x9's rear, 4x6's front. Radio reciever is mounted in passenger side rear compartment even with non-Bose. You will have to extend your wiring and antenna lead from there to the radio cavity. If you are installing a single DIN unit, you will need some type of dash kit. If you can't find one locally, shoot me an e-mail.
