Sponsored by: Innova
Bose Sub wired with rear speakers?
Old Jun 17, 2010 | 02:12 PM
sprinter1104's Avatar
sprinter1104
Default Bose Sub wired with rear speakers?
Hi All, last year I installed a Kenwood DNX 8120 in a 2000 C5 coupe using the Peripheral SVEN2. For some reason the subs in the doors are now tied in with the rear speakers. I've searched the forum and found some posts from others with the same issue, but no fix. If I use the fade control to shift music to the front channel it reduces the sub outputs.
How would I rewire the the SVEN2 interface to tie the subs to the front channels?
Old Jun 18, 2010 | 10:47 PM
markcz's Avatar
markcz
Without knowing how the sven2 is wired.... you could swap the front and rear outputs between the HU and interface. Your fade adjustment would be backwards, but the subs would adjust with the fronts.
