My D@$% Metra Bezel WARPED!
(holy $#!* was it hot... I lost 12 lbs doing it while drinking a ton of water too!). I took my time, took Friday off of work to make sure I had plenty of time to do it right... and made sure that when I mounted the HU (a Kenwood DNX7140, Monday night) that since the screen tilted forward and down that it cleared the bezel.
Upon closer inspection (but not too close as it was very obvious what the cause was) I noticed the whole D@#& METRA BEZEL WAS WARPED!
Has anyone else had this issue, and is there a better quality bezel that won't warp in the moderate heat that NJ is getting this summer?? (you folks from NV, AZ, NM, TX, FL, etc. experience this crap all the time, so please chime in)
Many thanks to all...
Jim
I switched to the bestkit trim pieces for my packages
