Pioneer w/Sirius Sat radio Help
Just purchased the Pioneer z120bt NAv and was wondering about the Sat hookup.
Right now it has XM Radio, which signal sucks where Im too. Sirius is much better here.
Was wondering cand the stock Xm antenna work with the
Pioneer Sirius Connect Bus Interface (CDSB10)?????
Or I have to buy another Antenna as well?
You can use the C6's orange SAT antenna cable.
The usual approach is to remove the orange plastic piece used for the OEM XM Tuner, it snaps off.
There are also antenna 'adapters' available and I'm not 100% sure that your Pioneer unit has the standard style antenna connection.
I'm sure one of the experts that have actually installed your model will have the definitive answer on whether you need an adapter or not.
