Sponsored by: Innova
Sub in Vert
Old Jul 25, 2010 | 05:20 PM
keyplyr's Avatar
keyplyr
Default Sub in Vert
Bose system w/ NAV in '05 vert. Cancelled XM and am currently splicing into the unit to input my mobile phone to play MP3s (thanks Ray Kawal.)
Been reading a bit and have talked to a couple of audio install shops. I'm thinking the best solution for me to get a bigger sound without a full replacement is:
  • Use a PAC line output converter to:
    • Add 4 channel amp (maybe Alpine PDX-4.150)
    • Add a Cleansweep type unit to flatten Bose signal.
  • Completely remove rear speakers along with the firewall.
  • Install either 8" or 10" sub box in trunk.
  • Replace door subs with good quality mid range.
  • Replace door highs with better quality high range.
I have a roolbar which wraps around behind seats & waterfall, prohibiting any use of space behind seats so I'm thinking that removing the rear speakers along w/ that firewall will allow better sound coming from the sub in the trunk, but I haven't though of any negative affect from doing this.
Appreciate any helpful comments. Thanks.
Old Jul 26, 2010 | 11:32 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
no need for a cleansweep at all
do a pdx4.150 or IMO even better kenwood xr4-s
2 way component set in doors, with woofer where oem sub was, and tweeter where oem twiddler was
ditch rear speakers, run sub of choice in rear
Old Jul 27, 2010 | 12:06 AM
keyplyr's Avatar
keyplyr
Thanks for the reply pentavolvo. I had previously read a couple of your earlier posts as research.
I also posted in C6 General since I didn't get any timely replies here in Audio.
I ended up keeping the Bose stuff except for the rears, which I removed along with the firewall to allow sound travel from the trunk where I installed a JL CS113TG-TWS which is a 13 3/4" sub speaker mounted in a slim fiberglass fully enclosed box in the trunk, powered by a JL HD 750 watt 1 channel amp.
I'm hoping that since I now have a dedicated powered bass, the rest of the system will sound better because I will no longer need to EQ the low end.
However I may end up upgrading the rest of the system, don't know yet. Remember this is a convertible, so much of the sound fidelity (or lack of) is not noticed, as I drive top down 95% of the time in sunny So. California.
Old Sep 14, 2010 | 04:55 PM
Tarheels1's Avatar
Tarheels1
How does your vert sound with all the changes? Do you have pics of it . Who did your roll bar?
To Sub in Vert
