Sponsored by: Innova
Installing dvd player help asap
Old Jul 29, 2010 | 11:52 AM
Xedes's Avatar
Xedes
Default Installing dvd player help asap
This is actually being done in my GF honda. If i don't hook up the parking brake wire, will it play the dvd while the car is in motion?
Thanks for any input.
Old Jul 29, 2010 | 11:57 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Without knowing the model impossible to say for sure... but odds are no. Typically if you hook those wires to ground then it will unlock all the in-motion stuff (the parking brake connection grounds when on) so if you just tie off that wire to the ground it should work. SHOULD work I say, cause no way to know for sure with what you provided.
Old Jul 29, 2010 | 12:24 PM
Xedes's Avatar
Xedes
Thanks.
Its a Pioneer AVH-P3200DVD (for the record)
Old Jul 29, 2010 | 01:51 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
not gonna work unless u do the bypass on it
To Installing dvd player help asap
