Sponsored by: Innova
Phone (Audio) Interrupt
Old Jul 29, 2010 | 08:07 PM
phil hunter's Avatar
phil hunter
Default Phone (Audio) Interrupt
I'm installing a new bluetooth equipped Nav radio in my C5 and am a bit confused about a brown wire on the radio called the Phone Interrupt. I know this has something to do with the bluetooth phone, but am not quite sure how it works. The manual says the following: "Connecting the Phone Interrupt Terminal. The phone interrupt will mute the audio if the lead receives a negative or ground signal". This seems to say that I should connect this lead to ground, but I don't understand where the signal comes from to mute the receiver. Does it come from the cell phone? Any help would be appreciated.
Phil
Old Jul 29, 2010 | 09:04 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
do not hook it up to anything
Old Jul 30, 2010 | 10:59 AM
phil hunter
Not sure I understand why this wire would not be used. Isn't it required to mute the radio when using the cell phone?
Phil
Old Aug 4, 2010 | 01:26 AM
AmmoVet's Avatar
AmmoVet
Got to the Audio FAQ area and look at SteveL2's instructions for installing a Parrot. In it he has found your answer. It is the white wire described in his instructions with the use of a SPDT relay.
To Phone (Audio) Interrupt
