Has anyone installed a motorola hf1000 bluetooth using the ABTI-GM1 harness? Couple of questions?
1-How does the voice mode work, does it understand commands ok?
2-If you have OEM Nav can you use your installed mic or did you use the motorola provided mic?
3-If possible can you tap into the mic wires to make it work?
