Sponsored by: Innova
Headunit install, speakers work not bass
Old Aug 6, 2010 | 07:56 AM
MR Turco's Avatar
MR Turco
Default Headunit install, speakers work not bass
Hi all.
So i installed my new kenwood radio last night along with the Pac Audio ROEM-VET1. I have all 4 high speakers but there is just no bass, sounds like the subs aren't on at all.
I am terrible when it comes to audio stuff but what i do know is the radio is "on" for a sub and i have adjusted the sub volume with no luck.
I have no adjusted the 4 gain controls on the PAC device, do i need to?
I assume the amp signal is working since the speakers work or am i mistaken?
Forgot to mention this is a C5 z06 with bose.
Thanks in advance!
Mike
Old Aug 6, 2010 | 09:30 AM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
how did you wire the pac roem-vet1 for the amp turn on wire?
the blue white from the radio goes to the blue on th epac roem-vet1
This is a Kenwood 6160 harness and the top wire will show th eblue white from the Kenwood(look close and you can make this out) to the blue of the pac roem-vet1
Old Aug 6, 2010 | 09:36 AM
MR Turco's Avatar
MR Turco
ah crap, let me check. I might have used the blue/white wire on the Pac. Thanks!
Old Aug 6, 2010 | 09:40 AM
MR Turco's Avatar
MR Turco
I just checked the wiring diagram and it says the blue/white is the amp signal and the blue is for power antenna on the pac. Is this incorrect from pac?
Old Aug 17, 2010 | 09:56 PM
MR Turco's Avatar
MR Turco
Yup the blue wire fixed it. my fault for not fully testing before install and trusting the diagram...
To Headunit install, speakers work not bass
