Sponsored by: Innova
Successful Bose Save
Old Aug 23, 2010 | 08:49 AM
rickso84's Avatar
rickso84
Default Successful Bose Save
Don't trassh the Bose amps and speakers... they aren't all that bad!
The CD and tape in my HU don't work so replaced it with a low-mid end Pioneer deck. Used preamp out through adapter harness to the Bose amp connector. Needed isolation transformers to remove turn-on thumps but sounds pretty good. The Bose amp modules, although not all that reliable, can usually be repaired if you're good with a soldering iron.
