I have a Pioneer in-dash unit DEH-P6000UB with appropriate Sirius interface module and remote tuner. This morning on my drive the radio played great on Sirius. When I went out for lunch I had no Sirius radio. The display on the in-dash Pioneer tuner shows the Sirius channel currently tuned in, and it also shows what song I should be hearing but I'm not. Please help me troubleshoot this problem. What is the likely culprit? Antenna? Interface unit? Remote tuner? Radio in-dash unit? The setup has worked great since activating it last year until today. All other functions of the in dash unit work properly.
Make sure you have an open view of the sky, I sometimes have problems if I go under an over pass or thick trees.
Do you have sound if you go to another source like cd or fm? if so try changing the channel on Sirius, remember that this tech is not the best and there are some problems. Check all your connections and make sure everything is secure.
Hope this helps you
