Sponsored by: Innova
Stock system no changes! Powerful hum and engine whine!
Old Sep 8, 2010 | 11:36 AM
Dream*66*'s Avatar
Dream*66*
Default Stock system no changes! Powerful hum and engine whine!
2005 with complete stock audio with nav. Have developed a loud whine and hum out of the front right door speaker. Even when I turn the car off, until I open door. Intermittent after hitting bumps. Have read other posts and will remove door panel. Am I looking for a SHORT or LOOSE GROUND? Any other pointers woul help. Thanks
Old Sep 9, 2010 | 04:55 PM
simpleman68's Avatar
simpleman68
I suspect you'll see a loose connection at the speaker/harness.
You may not. You may have a small cut in the speaker line that could be anywhere between the speaker and the head unit. Although, I'd look in the door first.
Hopefully just as simple as refastening a loose harness.
Scott
Old Sep 11, 2010 | 12:47 PM
m48xhp's Avatar
m48xhp
if you have stock Nav, then you have Bose. Id check the ground for the Bose amplifier.
Old Sep 11, 2010 | 10:45 PM
HANNY's Avatar
HANNY
once you ge tthe whine then start wiggling the harness and connections till it stops. theres you issue.
To Stock system no changes! Powerful hum and engine whine!
