Amp + Speaker Combination
Sep 17, 2010 | 03:04 PM
St. Jude Donor '14
Will this MTX 504X 600W 4-Ch amp:
http://cgi.ebay.com/MTX-504X-600W-4-...item1e5e647091
4 ohms: 50 watts x 4 chan.
2 ohms: 75 watts x 4 chan.
Bridged, 4 ohms: 150 watts x 2 chan.
Power my new CTX65CS - Image Dynamics 6.5 speakers adequately?
http://www.woofersetc.com/p6201/CTX6...ker-System.htm
RMS Power Handling: 100 Watts
Peak Power Handling: 200 Watts
Frequency Response: +/- 3 db 58hz-22khz
Efficiency @ 2.83 volts: 93dB
Impedance: 4 Ohms
Sep 17, 2010 | 04:54 PM
Cruise-In IX Veteran
well it puts out 50rms and ur speakers handle 100
Sep 17, 2010 | 06:17 PM
I would bridge it for 150x2... Overhead is nice.
Sep 17, 2010 | 07:24 PM
St. Jude Donor '14
Quote:
Originally Posted by
Kale
I didn't even think about that.
75 seems good enough.
Thanks.
Sep 17, 2010 | 07:25 PM
You can turn 150watts down but you can't turn 75 watts up. (Well, with bass boost, but you don't want to wreck your speakers, right?)
I run about 900watts total to my front speakers. I was thinking about upgrading.
Sep 17, 2010 | 11:32 PM
Gattaca
Thanks.
where do you get 75, its only 50 at 4 ohms
Sep 18, 2010 | 01:20 AM
St. Jude Donor '14
150 RMS at 4ohms with 2 channels.
If I use the bridged connection and tap into 2 speakers per channel that should give me 75 RMS at 4 ohms for each speaker.
Or at least that's how I understand it.
Sep 18, 2010 | 10:04 AM
pentavolvo
I think he misunderstood the amps ratings.
Gattaca, I would NOT take any bridged channel and try to run 2 drivers off from it.
That sounds like a quick way to toast your amp if not your speakers.
Scott
Sep 18, 2010 | 10:13 AM
To clarify: If you take a 4 ohm channel and run 2 4ohm speakers off from it, you'll be dropping down to a 2ohm load. (Other than a series/parallel wiring config) Most amp companies recommend not reducing the ohm load of a bridged channel.
If you plan on wiring in parallel, you're wasting your time as you'll be getting virtually the same power by running in 4 channel config. Wiring in parallel will maintain a 4ohm load but reduce the power to each speaker to what you would have had if you hadn't bridged the channels.
Scott
Reason: typo
Sep 18, 2010 | 10:45 AM
St. Jude Donor '14
Thank you for the clarification.
I've been looking for an amp that will fit underneath my seat, and it seems that the higher the RMS the bigger the amp is.
Sep 18, 2010 | 11:13 AM
Gattaca
Yeah man, need room for those monster capacitors.
Scott
Sep 18, 2010 | 11:09 PM
what exactly are you wanting to power, and other then fit under seat what requirments
Sep 19, 2010 | 12:09 AM
You only need to amp 2 speakers.
Unless you mean to amp the tweeters and mids separately, that's a different beast entirely.
If you want rear fill... power inexpensive rears with head unit and turn them down.
Also, check out Arc Mini.
Sep 19, 2010 | 02:36 AM
St. Jude Donor '14
Kale
I didn't even think about that. I can supply the rear fill with the head unit. I forgot how useless it really is.
Thanks everyone.
50 ,
amp ,
combination ,
connected ,
ctx65cs ,
dynamics ,
image ,
ohm ,
ohms ,
run ,
speaker ,
watt
