Sponsored by: Innova
standard size for double din opening in bezel????
Old Sep 30, 2010 | 11:20 AM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Default standard size for double din opening in bezel????
I'm a little confused about the opening in the C5 bezel as it relates to the DD products out there. I see anywhere from 6.5 inches to 8 inches for screen sizes, so does this mean I need to buy the HU first, then modify the bezel later to fit correctly? What dimensions have you guys been making on your bezels, and are there any gaps or other issues?
thanks
Old Sep 30, 2010 | 11:49 AM
Kale's Avatar
Kale
Din is a unit of measure.
One Din is 7x2
Double din is 7x4
The only real variation is the curvature of the corners. Sometimes head units are square, sometimes they are nicely rounded (usually.)
Old Sep 30, 2010 | 01:05 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
radios for the most part are all the exact same size
the screen size is the only difference and its because of the features of the radio.
only have to worry aboutt he off brand hong kong units. these are a nightmare as they are all different sizes
Old Jan 30, 2012 | 10:55 PM
KenI's Avatar
KenI
What size are people making the C5 bezel to fit a double din radio?
7x4 or a little smaller?
Old Jan 31, 2012 | 04:42 PM
JOHN/WS6's Avatar
JOHN/WS6
If you personally wants install the HU, I suggest that you buy the HU first and modify the bezel later to fit correctly. The Last week I bought a Pioneer AVH-3300BT and with a few modifi in the radio bezel, I installed it, Just cut a few mm of the bezel top, and modifie the radio aluminium support.
Old Jan 31, 2012 | 04:54 PM
KenI's Avatar
KenI
Thanks. I have an old bezel that I had cut the ash tray out of a while back. I did that for a sat radio. I since replaced it with a new bezel so I still have the cut up one. I was going to cut it up further for a double din and no ashtray. I haven't picked out which radio to go with yet though.
Old Jan 31, 2012 | 05:28 PM
JOHN/WS6's Avatar
JOHN/WS6
I will share some pics about it.
To standard size for double din opening in bezel????
