Sponsored by: Innova
Help Removing Metal Support Plate?
Old Oct 30, 2010 | 09:43 PM
Techsan's Avatar
Techsan
Default Help Removing Metal Support Plate?
I am installing a double din head unit and I have not been able to remove the rivots that hold the metal plate that supports the head unit. I have a right angle drill and I bought a good quality metal drill bit, but it is not even making a dent on the rivots. Any help would be greatly appreciated.
Old Oct 30, 2010 | 10:36 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
sawzall
Old Oct 31, 2010 | 04:34 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Originally Posted by pentavolvo
sawzall
I tried to drill them also... Sawzall took about 5 min
Old Oct 31, 2010 | 09:51 AM
Lancejoker's Avatar
Lancejoker
Just for future reference,when you take that plate out,do you just flip it upside down in the same position for the double din headunit or is it no longer used.
Old Oct 31, 2010 | 10:42 AM
Techsan's Avatar
Techsan
Thanks for the help, I will do it that way. To answer the above post, I dont think you would use the plate again, especially if you saw it out.
Old Oct 31, 2010 | 11:45 AM
ICULUKN-C5's Avatar
ICULUKN-C5
No longer needed
Old Oct 31, 2010 | 12:30 PM
Lancejoker's Avatar
Lancejoker
Gotcha thanks
Old Nov 1, 2010 | 08:39 AM
tech2262's Avatar
tech2262
Right angle drill worked for me
To Help Removing Metal Support Plate?
