Sponsored by: Innova
How many feet?
Old Nov 3, 2010 | 05:15 PM
Lancejoker's Avatar
Lancejoker
Default How many feet?
I'm mounting the amp on the back wall of my coupe. Going to be running wires to the doors for the mids,a pillars for the tweeters and from the headunit to the rear speakers. For you guys who have done a ton of installs,how many feet of speakers wire should I order?
Thanks guys.
Old Nov 3, 2010 | 05:52 PM
Gitusum's Avatar
Gitusum
Thanks guys.
A butt load i ran speaker wires for each speaker which i have a 3 way front stage and it seems like about 100ft of wire
Old Nov 4, 2010 | 02:45 PM
nickwfd92's Avatar
nickwfd92
Lance
I used approx. 60ft for all my speakers but I have my amps mounted behind my seats. I would say if you get 100 ft I used 14ga. all around you should be good. I always say buy more wire because you dont want to be installing and then find out that you dont have enough.
Parts express and Monoprice has some good prices on wire.
Good luck.
nick
Old Nov 4, 2010 | 04:13 PM
Lancejoker's Avatar
Lancejoker
Thanks guys. I appreciate the help.
Old Nov 4, 2010 | 04:47 PM
RAAMaudio's Avatar
0RAAMaudio
Former Vendor
You can spend a ton on speaker wire or get decent wire for cheap and be fine, I used Wire King on my $20k system because it was fine
You can buy wire at Walmart(I try not to shop there, mainly just buy oil) in spools for decent prices and it is ok to use.
Measure and add at least 20% for each wire, you want some slack as tucking it in here and there really sucks up the length, to short sucks!
I run 16 to tweeters, 14 to mids unless high powered then 12 gauge but it depends on the length, the longer the wire or higher the power, the heavier the gauge needed.
I am installing high output midbasses in my truck, 250 watts feeding them, running 10 gauge to them to be sure.
Rick
Old Nov 4, 2010 | 06:33 PM
markcz's Avatar
markcz
Home Depot actually has pretty good prices on decent speaker wire. In my local store they have the wire separated into good/better/best on the shelf. 100' of 16G "better" is only $20.
Old Nov 4, 2010 | 06:44 PM
RAAMaudio's Avatar
0RAAMaudio
Former Vendor
Just get OFC wire and you will be fine.
Oxygen Free Copper
but I would not run 16 to mids unless really short runs
To How many feet?
