Sponsored by: Innova
Popping and cracking
Old Nov 6, 2010 | 09:28 PM
Harleyrocker's Avatar
Harleyrocker
Default Popping and cracking
My 98 has the bose stereo, the driver side speaker is popping and cracking, my local stereo shop said it sounded like the amp in the speaker was bad, so I bought a good set of bose front speakers and put it in today, it is better but still doing it some ,the guy I bought the car from kept the interior wet with armor all or something , could it be the deck itself , and not the speaker. Please help. Thanks
Old Nov 6, 2010 | 10:27 PM
Harleyrocker
Please help, I dont know where to start now,
Old Nov 6, 2010 | 10:41 PM
markcz's Avatar
markcz
You need to determine if it's the 3.5" twiddler or the sub that's bad. Turn the fade/balance ***** so only the bad set is playing, then adjust the tone all the way up/down to find out which speaker is bad.
If it's the sub, your best bet is buying a take-off from someone who replaced the entire setup. If it's the twiddler just buy any aftermarket 3.5" 4-ohm 2-way set (Polk db351 are popular).
Old Nov 6, 2010 | 10:59 PM
Harleyrocker
when i turn it all the way down you can still hear it , making a popping sound, I have just replaced the entire driver side set.
Old Nov 7, 2010 | 12:06 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Does it do it when the car motor isn't running?
Old Nov 7, 2010 | 05:33 AM
Harleyrocker
Yeah , it does it when the car isnt running.
Old Nov 7, 2010 | 01:50 PM
markcz's Avatar
markcz
If it's only bad on the drivers side, and you can't isolate it to twiddler or sub with controls on the radio, then you need to pull the door apart for a look at the speakers. If you're lucky it will be a visually obvious physical problem.
If the speakers look OK, then you can rule out the radio by swapping pass side set with drivers side to see if problem moves or stays put. if it moves, speakers. If it stays, radio.
Old Nov 7, 2010 | 06:38 PM
Harleyrocker
I put a completely different speaker assembly in the driver door I bought off ebay, it didnt change anything, so then you are saying it is the radio, what about the other thing people talk about that is under the dash or something,.
Old Nov 7, 2010 | 07:09 PM
markcz's Avatar
markcz
There is a Bose 'signal processor' in C5, above and to the right of the gas pedal IIRC. If you're sure it's not a speaker, it could be that or the radio. If it were my car I'd still swap the speaker assemblies left to right and see what happens.
Old Nov 7, 2010 | 07:20 PM
Harleyrocker
Mine is a convertible, is the processor in the same place?
Old Nov 7, 2010 | 08:18 PM
markcz's Avatar
markcz
I believe it's above the gas pedal in all C5. The plastic trim is easy to remove, just pull straight down on the round push pins along the front edge and it will fall to the floor if you pull it straight back towards the seat.
To Popping and cracking
