Navigation Unit Replaced Twice in Three Weeks!!! - Your Thoughts???
Been using a bootleggged disc I downloaded and burned off the internet for about a year and a half. I think it's V5.0.
Three weeks ago unit gave a message that the disc in DVD is not a map disc. Replaced with a new OEM disc and unit wouldn't read it either or any other disc the dealer tried. Kept giving the not a map DVD regardless of the disc they tried.
Put a new unit in and it worked fine and read my bootleg disc for 3 weeks only to then give the same message and again wouldn't read ANY disc.
Dealer replaced again and this time stated the disc I burned was the problem. I think they're making it up. Isn't the unit just an optical reader? How could a disc that has worked fine for 1.5 years cause this problem!?!?
Rick
** Edit..
I missed the part about the original disks not being read either. If its really killing your nav and factory disks cant be read either, that is really weird. I cant imaging that the boot legs software could kill a head unit. Do updated the nav disks do any kind of software update to the head unit? If so, that could render the head unit incompatible with older disks.
Just my 2 cents.
Mr.Bill
If they'll give you another new one, try only using the original DVD for a while. If the problem is somehow coming from elsewhere in the car (unlikely, but possible) then the new unit should die even with the oem dvd. If it works for 6 months, then you switch back to the bootleg maps and it dies in weeks, dvd is the problem.
That being said, the only way I can see the new DVD causing the problem is if it somehow updates the firmware on the nav unit. If all the DVD has on it is map data, then it can't be the issue.
