Sponsored by: Innova
Building sub box for '99 FRC
Old Apr 7, 2002 | 01:46 AM
The Edge's Avatar
The Edge
Cruise-In III Veteran
Default Building sub box for '99 FRC
I'm wanting to build a box for my Hardtop out of MDF. I am trying to keep the outside dimensions to 11" tall, 45" wide, and minimal depth ( 6 or 7" if possible). This is to fit in the space where the partition would go in a FRC (directly under the rear window). To take up as little space as possible without compromising too much sound quality, what is the minimal depth I could make the box and what sub(s) should I use? 1 or 2 10" subs or 2 8" subs? If I have the volume that the sub(s) requires, is it ok if the rear of the magnet is within an inch or so of the back of the box?
Old Apr 7, 2002 | 07:12 PM
JoeyG's Avatar
JoeyG
Cruise-In IV Veteran
Default Re: Building sub box for '99 FRC (edge99hardtop)
Allow at least a 1/2 " from the backside of the speaker magnet to the face of the box wall, for cooling if the speaker has a voice coil vent hole. 2 - 10" subs with the same amount of power will move more air, ie slightly louder than 2 - 8's. Depending on how much room you want to use up or keep would also be a determining factor, as well as how loud and what type of music do you primarily listen to. God Luck. :yesnod:
[Modified by JoeyG, 5:13 PM 4/7/2002]
Old Apr 8, 2002 | 12:48 AM
mrkln's Avatar
mrkln
Default Re: Building sub box for '99 FRC (JoeyG)
Yep. What Joe said. :yesnod: I myself have elected to go with a single 12" IDMAX in the center well of my coupe.
You might want to check out the box that GraveDigger built for his FRC. It looks great. Here is a link to the thread.
GraveDiggers aftermarket stereo
:cheers:
[Modified by mrkln, 10:55 PM 4/7/2002]
To Building sub box for '99 FRC
