C5 iPod install
remove bezel
remove radio unplug harness from radio
plug in new setup
run ipod cable
reinstall radio and bezel
45 minutes to an hour install
http://www.doubledmods.com/Periphera...ter-ipodc5.htm
This one will allow you to unplug your cd changer harness
plug the new kit into it
run the cable to front of the car your done
maybe 5 minutes
http://www.doubledmods.com/Periphera...ipipodghm2.htm
you can controls both from head unit
both will charge ipod as well
This setup gives you limited control of the IPOD. You won't be able to run up and down through the menu, but you will be able to forward and reverse search through an album or playlist.
