Sponsored by: Innova
Amp trigger on C6
Old Dec 23, 2010 | 09:29 AM
Buddy A's Avatar
Buddy A
Default Amp trigger on C6
Can someone confirm if the white wire on B3 of the harness will give the delay to match when the radio turns on and off. I searched and couldn't confirm this.
Thanks,
Buddy
Old Dec 23, 2010 | 07:08 PM
markcz's Avatar
markcz
It will definitely stay on with RAP after you turn the car off, it's the trigger wire for the oem amp (as long as you have the stock radio installed).
The only issue B3 has (that others have reported) is that due to the way the radio generates the warning beeps it's hot whenever the car is running, even if the radio isn't on. That just means whatever you trigger with it will be on whenever the car is running, even if the radio is off.
Old Dec 23, 2010 | 07:28 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
if i recall it turns off like 10 sec after u shut radio off even with car running... if it needs to chime it will fire back on
Old Dec 24, 2010 | 03:32 PM
Buddy A's Avatar
Buddy A
Thanks guys. On my last C6 install, several years ago, I used the seat heater fuse. Didn't like that as much.
To all my CF brothers and sisters, Merry Christmas and Happy Holidays. Hope everyone has a safe and enjoyable time.
Buddy
To Amp trigger on C6
