I just had a shop install the z110bt everything worked great at first an just an houR later the sound went out then came back after 10 minutes then a week passes happens again comes back after 10 minutes last night again but this time it's not coming back there is no noise at all everything works but the sound all menus nav work fine ... I don't have the mute or ATt coming up on the screen...no noise at all like speaker poping when pluging in the RCA ...I think the amp is not turning on...
2008 corvette Bose with steering wheels control
I had the exact same issue with my install, which I did myself, and the jumper relay did the trick. I just got a relay at the local auto shop and installed it per the bullitin and all worked great.
