Damn. That's not a bad installation. Did you wind up having to trip the dash at all? Where did you get the trimout?
This might not be a bad option.
:confused: Trim the dash :confused:
Yes, I snipped the lower corners on both sides of the face plate to help it over the new units facing. As far as what's behind that, it's the exact same size as stock. Since the old unit was shot, I used a rotory tool to cut out the sides of the old, then I bolted them to the new. That way it mounts in the factory location. Biggest chore was all the wiring. :yesnod:
I'm looking at another 96 that is a non-bose car, and already has a cheap DIN radio installed. If I get the car I'll either:
A) See if I can swap a used Bose Gold system in (yeah, yeah - I know, its old....yada yada - but it also doesn't look like bubba hacked a ill-fitting video game in his dashboard)
B) Go with a complete double DIN setup and replace all the system wiring.
Fortunately, I don't have the car yet so I don't have to make any decisions quite yet.
Since its double din, you have three choices. A: put in a double din radio. I'm biased against this as they usually cost more for the same features and performance and I don't like the look. Looks fisher price to me.
The second choice is use two din units. CD and DVD, CD and Tape, CD and EQ, etc. The last option is find a kit that has a single din and a storage pocket filling the other slot. This is the way I would go. I don't know of one in particular so you'll have too look around a little but they're out there. Great place to store CDs also.
Agreed. All those options will be considered. The double component idea is great if I can find the right combination that will give the components I want, they look good together, and they can be relatively easily intergrated. It looks like some manufacturers are actually making stuff to combine into a double DIN chassis so some of the guesswork is gone.
A single DIN with some sort of stoarge slot might be OK if I can find the right thing. What I can't stand is something that is so obviously NOT part of the interior. Most DIN installs look terrible. Like this:
