Sponsored by: Innova
Anyone build an amp rack?
Old Apr 8, 2002 | 09:48 PM
FarmerBob2001's Avatar
FarmerBob2001
Default Anyone build an amp rack?
I'd like to build an amp rack that sits right behind the seats at the forward edge of the hatch area. Anyone have plans on one?
What type of wood should I use? How do I secure it to the hatch floor (God forbid I'm ever in a wreck, I don't want that thing flying around the car..)?
Do most people build a rectangle of wood? i.e. do the amps sit on a piece of wood, with another piece flush with the tops of the amps?
Or do most people have the amps on the hatch floor with just a single piece of wood flush with the tops of the amps?
Also, I'd prefer the install to be stealth. I don't really need to be able to see the amps. I just want them mounted securely, with a way to get to them when needed for adjustments, etc.
Any suggestions or plans would be appreciated. Thanks.
Old Apr 9, 2002 | 09:30 AM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Anyone build an amp rack? (FarmerBob2001)
If I remember correctly IndyPace78, had a nice one made of particleboard/plywoood(?) with carpet covering. Mine is made of a base piece of 1/2" Birch which spans from rear speaker to rear speker in my coupe hatch. The piece has routered tabs, which have the trim plastic residing in the grooves holding the rack in place. I then made a semi-arc cover shroud, it starts by the top storage bases and gradually curves over the amps, finally resting over the hump right behuind the passenger/driver seats. It's a one piece top that is secured using dowl pins (fiberglassed into the cover) and locator pin holes mounted to the rack itself. So the top cover can only be removed from the rearward direction. I'll have pics in a week or two when work slows down.
[Modified by JoeyG, 7:31 AM 4/9/2002]
Old Apr 9, 2002 | 09:42 AM
lotzahp's Avatar
lotzahp
Since most folks don't like to have holes drilled in their body pan, one trick I've seen used is to secure small blocks of wood to the body pan with Liquid Nails. Then, something like an amp rack or speaker baffle would be screwed to the blocks. It's a very secure mount and completely reversible if necessary with minimal evidence of it ever being there.
Old Apr 9, 2002 | 12:03 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: Anyone build an amp rack? (lotzahp)
Nice trick.
Old Apr 9, 2002 | 02:55 PM
FarmerBob2001
Default Re: Anyone build an amp rack? (JoeyG)
Joey,
What did you make the curved amp cover out of? Sounds pretty cool. Hurry up and get those pics posted.. :)
I also like the liquid nails/blocks of wood idea. What is liquid nails, an epoxy of some sort? Can it be removed?
Thanks for the ideas..
Old Apr 9, 2002 | 04:23 PM
lotzahp's Avatar
lotzahp
It's construction adhesive found in your favorite hardware store in a caulk tube. I think they make different flavors for specific materials (wood, masonry, etc). It's pretty strong when totally cured. You can remove it by scraping it off with a putty knife & a lot of elbow grease.
Old Apr 9, 2002 | 08:50 PM
JoeyG's Avatar
JoeyG
Joey,
Liquid nail can be removed, but it's some strong stuff!!
I used wood teplates for the sides and a cut-down version for the center between the amps. Then I went to town using about 6 layers fiberglass resin and matting.
Old Apr 10, 2002 | 09:03 PM
YO-EL's Avatar
YO-EL
Old Apr 10, 2002 | 11:47 PM
Black01Coupe's Avatar
Black01Coupe
Default Re: Anyone build an amp rack? (indypace78)
indypace78. How is your amprack secured?
Old Apr 11, 2002 | 09:07 AM
YO-EL's Avatar
YO-EL
Default Re: Anyone build an amp rack? (Black01Coupe)
I'm not really sure since I didn't do the install, but I know the equipment is mounted on a wood plank. I don't think anything is drilled into the car body.
Sorry I can't give more info.....
To Anyone build an amp rack?
