Ok guys, I'm in trouble here. A friend of mine had his 2009 c6 setup with a full system running off of the factory radio. The shop that did the install cut off the c2 connector from the factory amp. We need to put the car back to stock, but have no idea what pin is what. I have searched the forum and the web high and low, and can not find a pin out of this connector. It is a 16 pin plug, and has the speaker outputs for the center, front mids, and rears, and a few other wires as well. If anyone has info on this, I would really appreciate it!!! The car is a 2009 z06, with bluetooth, bose, and onstar. U65 is present on the glove box. PLEASE HELP!!!!!!
Thanks for the quick replys, but this is not the same as the amp on this vehicle. (I found these pinouts in my searching, but they both show a 24 pin plug, mine is a 16 pin) Those pinouts in the faq section also show only 2 plugs at the amp, the amp in this car has 3!!!
So far, I have found the locations of the fronts, the mono rear out, and the center. Im just not sure about the polarity of each.
