Sponsored by: Innova
C6 audio system setup, need some advice
Old Jan 28, 2011 | 04:26 PM
Thrillhouse's Avatar
Thrillhouse
Default C6 audio system setup, need some advice
I'm preparing to swap out the stock Bose system in my C6. I've already ordered all of the insulation and door parts from Rick at Raamaudio, I've also ordered a Pioneer z130 from Dennis. What I'm trying to figure out now is the sub, speakers and amp/s.
Originally I had planned to reuse some equipment I have leftover from an old car, but after digging it out from storage it's not in very good shape. It's looking like I'm going to need all new gear after all. My old Kappa Perfect 10DVQ sub might still be usable, but I think it might be too deep to fit a corner box in a C6 (plus it's tough to find a sub box for the car other than the JL Stealthbox)
It seems nearly everyone on here swears by Image Dynamics and Arc Audio gear. I know Rick recommends Arc amps. The thing is that I'm on a bit of a budget and I don't really want to spend a huge amount on the speakers and amps. I do, however, care about retaining as much of the trunk volume as possible, I also want my install to be difficult to see from outside the car as I've had stereo gear stolen in the past and really don't want to deal with that on the Vette.
So my current thought is to get a single Arc 4 channel mini amp, a JL Stealthbox, and a set of Image Dynamics CTX 65CS components. I want to mount the amp under the passenger footboard where the stock Bose amp normally is, run the front channels to the components and bridge the rear channel to the Stealthbox.
Does anyone know if the Arc amp will fit in that location? Anyone have any pictures of a previous install? Is there adequate cooling underneath the carpet for the amp? Will that long of speaker wire for the sub cause any problems? Is there anything wrong with the lower tier of Image Dynamics equipment?
I want to stress that I am really not very picky with stereos. My previous setups have used cheap stuff like rockford fosgate amps, sony xplod speakers, and JL W0 subs and I've been perfectly happy with them. Pretty much my only requirement is silk dome tweeters as I've found the metal ones to be overly harsh.
Old Jan 28, 2011 | 04:40 PM
ROC OUT's Avatar
ROC OUT
I have the ARC Audio Mini 4-channel under the passenger side floor board (where the Bose amp was) and it fits there fine. I have never had a problem with ventilation either. Others have used this amp in this exact location with no problems. Sorry but I don't have pics of the install.
Good luck!
