Sponsored by: Innova
My new Components, What do you Think
Old Jan 31, 2011 | 03:08 PM
okie08vette's Avatar
okie08vette
Default My new Components, What do you Think
So let me know what you think about my new new Amp and Speakers I am putting in my 08.
I have a Pioneer AV120 head unit in and don't currently have plans for a sub.
So what do you think.
Cost is variable as I got a great deal on this from Dennis, at Double D Mods, not sure of exact pricing until he gets the VIBE line completley in his inventory but knowing Dennis he will be unbeatable.
AMP
VIBE Audio SLICK A1 (SLICKA1)
800W Max,
RMS Power Rating:
4 ohms: 75 watts x 4 chan.
2 ohms: 100 watts x 4 chan.
Bridged, 4 ohms: 200 watts x 2 chan.
Max power output: 800 watts
Pulse Width Modulated MOSFET power supply
Remote bass level input (remote level control sold separately)
LED power (green) and protect (red) indicators
Selectable bass boost (0, 6, 12 dB at 45 Hz)
Soft Start Turn-on
4/3/2 channel operation
Speaker-level inputs with signal sensing for automatic turn-on
3-Way System Protection circuitry (thermal, overload, and speaker short protection)
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Gold-plated RCA level inputs
Gold-plated screw terminals
Input sensitivity:
Level: 200mV-6V
Variable high-pass filter (45-300 Hz, 24 dB/octave)
Variable low-pass filter (45-300 Hz, 24 dB/octave)
CEA-2006 compliant amplifier
Frequency response: 20-20,000 Hz
SPEAKERS
VIBE Audio SLICK 6 V3 (SLICK6-V3)
6-1/2" Slick Series 2-way Coaxial Car Speakers
3/4" Silk dome tweeter for smooth high frequency response
Peak: 480 watts per pair / 240 watts each
RMS: 160 watts per pair / 80 watts each
Minimum: 90 watts per pair / 45 watts each
4 ohms impedance
1" voice coil diameter
Vibe Audio SLICK40-V2
4" Slick Series 2-Way Coaxial Car Speakers
Peak: 300 watts per pair / 150 watts each
RMS: 100 watts per pair / 50 watts each
Minimum: 50 watts per pair / 25 watts each
Old Jan 31, 2011 | 04:42 PM
markcz's Avatar
markcz
Re the speakers, why 4" vs. oem 5.25 in the back?
Also, why not go with components instead of coax in front. If you're pulling the bose subs to put in 6.5's you'll need to make/buy plates anyway.
Old Jan 31, 2011 | 04:44 PM
NYC6's Avatar
NYC6
Are you using the 6.5 coax up front? If yes, why?
Are you using 4" coax out back? If yes, why not 5.25"s?
Old Jan 31, 2011 | 05:23 PM
okie08vette
OK, really messed this up, did not look to close just copied the spec's and pasted. The speakers I am using are Vibe but not the one's listed. I have 6.5 component speakers in the front for the doors and tweets and 5.25 for the back.
I guess I was really looking for some input on the "VIBE" brand seems to be a new brand from England and I can't find much out about it. The spec's look good hope to have it all hooked up this weekend for a test run then complete the install next week.
Old Jan 31, 2011 | 07:49 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
u will like
To My new Components, What do you Think
