Sponsored by: Innova
94 Radio issues
Old Feb 8, 2011 | 06:47 PM
rob-cyn's Avatar
rob-cyn
Default 94 Radio issues
Can someone steer me in the right direction ? I bought a nice Pioneer double din unit that came with the wiring harness and antenna adaptor. I removed my stock delco unit which appears to not be a Bose and the harness does not match and there was no antenna connection to the radio so I am obviously missing something here right ?There are 2 plug connectors in the dash, one with 7 wires and the other with 9. They sent a Metra 70-1858 which says it does a Corvette but ?
Old Feb 9, 2011 | 12:01 AM
vetteright's Avatar
vetteright
Need more information. Are you attempting to install the unit into a C6, C5, etc.? Bose or non-Bose in the car now? What model Pioneer? Do you have OnStar, XM or Sirius and if not now, are you going to want any of them in the future? Aftermarket amplifier/speakers/sub? All of these factors, and probably others, will affect your installation and any advice any member here can offer.
Old Feb 9, 2011 | 08:56 AM
rob-cyn's Avatar
rob-cyn
Sorry. Its a 94 C4, non Bose. Installing a Pioneer3200DVD. I basically need to know if there is more to the radio system than I took out since I cant find an antenna cable and the Metra harness does not match up
Old Feb 10, 2011 | 05:15 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Refer to the C4 FAQ at the top of the section. It should answer all of your questions.
Randy
To 94 Radio issues
