95 C4 install questions Bose replacement
I currently have a 1995, with Bose Gold, I want to replace it, with a new head unit, of course I will need 4 new speakers, and have to run new speaker wire for them to replace all of the Bose junk. I also plan on adding a small amp and sub in the back, but I know I can do that, as once all the Bose is out, it will be the same as in other cars.
I have already looked and my actual stereo is in the back storage bin, and the Bose head unit is actually just for display right? That’s how I understand it, so if that is correct I need to run new wires from the bin to the stereo to for power, antenna, constant, and dimmer right? My question here is what wires are they, or is there an adaptor I can by to plug in, to the wires in the bin then run to the new head unit? Hoping for the adaptor, as it would be the easiest solution.
What are good CD players that will fill the 1.5 din, or a link to a mounting kit for a single din?
Lastly I’m not sure I get what needs to be done to keep from getting a light from coming on, I have read it, but want to make sure I get it.
Thanks in advance for your help. I think I can do this, although it will be the largest electronic install I have ever done, and just want to make sure I know exactly what I’m getting into.
you deff wanna go with a single din radio
Why do I want to go single din? Is it not possible to do a double? I found this mount http://www.doubledmods.com/Corvette-...l-kit-GM37.htm
I know Vrum Vrum on here used to make a nice one, but he isn’t making them now.
Any additional advice or pics ppl may have of their set ups are much appreciated.
Thanks everyone for the help. I have picked out what I think I’m going to order, and plan to get started pretty soon. I am going on a budget, so nothing to expensive, but I have found a nice set of 6x9 Rockford Fosgate, some 5¼ Kickers for the front, and a Boss head unit. I know lots of you probably won’t like the Boss unit, but I install one into my father’s car a few years back and have been very happy with it, for the price. One day I might replace it with a double din navigation anyway, but not anytime soon.
Also I’m going to go ahead and wire it for an amp and sub, but not sure if I’m adding it right away. I think I will be going with a 10inch Kicker here, but haven’t found an good amp at a good price yet. It’s a 4 ohm 300 watt sub, I was planning on getting a two channel and bridging it. Any suggestions on a cheap good amp?
Lastly again what does anyone have a brand and model number of the correct harness I need? I found one online http://www.ecklers.com/corvette-radi...1990-1996.html but was hoping to pick one up locally so I could get started while I wait for stuff to come in.
Also need to know the correct antenna extension?
