C5 with Multi Amp, Multi Sources, got a ground loop/noise question...
I have a Pioneer Head Unit, Pioneer DSP EQ, 5.1 channel surround processor for control over a center channel, Soundstream 5 channel Amp, and a Boss 2 channel amp. I have developed a ground loop that is pretty persistent. With the engine OFF and key on I get this noise: It's the typical hum/high pitch sound but also sounds like Star Trek if you listen close. The noise hisses, then changes pitch, then sounds like a synthesizer, noise goes up and down the frequency curve and then all of a sudden will completely suppress itself for a second or two and then it starts again. It is not a repeating pattern and changes what it will do each time the Head Unit and DSP fire up. I have isolated it down to the 2nd amp (Boss 2 channel) and the 5.1 Surround Sound Processor. When I change the grounding points from the rear chassis to the passenger seat bolts it almost completely eliminates the noise but you can still hear it faintly. I also know if I turn the gains down more on the 5.1 channel processor the noise also becomes quieter, BUT that hurts the volume level of the center channel so I would rather not do that.
Ok soooooo....believe it or not I always was led to believe that grounding all sources to 1 point was a BAD idea...but it seems I have read a few posts saying to do this....opinions?
Been working on the problem for a few nights now. I really would like to eliminate the noise completely. It is faint now with the new seat grounding points...but I still know it's there.
I have my power wires running down the passenger side. RCAs running down the middle of the car with the speaker wires as well. The power lines only come in contact in one area where they must cross over the RCA's. I couldn't avoid that cause the power hook ups on my amp are on the far left side. The amp is mounted on the center rear bumper wall. Had to get the power over to there. I did test and hold the power wires up and away from the RCA's just to be sure that was not where the noise was coming from. It made no difference. My gut is telling me...it is just a bad ground loop because I have 5 sources all having different grounds. Amp 1, Amp 2, Head Unit, DSP, & 5.1 surround processor. The head unit and DSP are grounded up front on the radio bracket attaching it to the car chassis. The Amp 1, Amp 2, & 5.1 surround are all grounded in the back (cause that is where they are located) to 3 different spots on the chassis.
So if I ground the 3 big sources in the back to a common ground...do you guys think that will help? I am going to try that tonight...it is really the only thing I have not tried yet.
Just looking for ideas and opinions....
If someone has a nice different brand amp to test I would try it but I only have 2 different amps (granted they are both Boss) and I have the same problem with both of them. I take them out, put them in a different car...no problems.
it also sounds like you have alot of Y's in your rca wiring, try just running one cable all the way thru for testing purposes and introducing Y's one at a time to zero in on the faulty junction.
if switching the amps is not an option you can borrow my spare alpine v12 4 or 2 channel for testing if you promise to return it
peace!
mike
also your probltm sounds like your getting a ground through the rca's a lot of cheap amps share the ground with the rca ground, if you install a ground loop isolator which can be found at radio shack or walmart it will electrically isolate the ground from each component. try installing one between the processor and the amp and i bet it solves your problem.
