Sponsored by: Innova
new to corvette
Old Apr 3, 2011 | 05:33 PM
taahring1's Avatar
taahring1
Default new to corvette
just got an 07 coupe with the bose sound system, my previous car (mazda rx8) also had a bose system but it got completely ripped out and replaced after the door speakers went out. my plan is to do the same to the bose system in the corvette because going from a $3000 system in my other car to the bose is like going from blu-ray discs to vhs tapes.
from what i can tell the systems are very similar as far as what has to be done to replace the headunit and speakers, i went through this page http://forums.corvetteforum.com/audi...ll-a-head.html
and notice you need the adapter which is this PAC part
http://pac-audio.com/productDetails....&CategoryID=26
my question about it is what are the rca cables on it for? input or output or what?
secondly, for replacing the speakers is there anyone that makes pre fabricated mounting adapters for 6.5" speakers in the door cutout?
also are the doors sealed or is that something i should look into doing?
just looking for some general advice here, i plan on using a pioneer 3300bt, kicker ix1000.5, 6.5 components upfront and 5.25 coax in the rear with 2 10" subs. need to know anything special needed to make this happen
edit: and yes i know i need a double din frame kit and antenna adapter, its the special integration kits i get messed up with
Old Apr 3, 2011 | 07:43 PM
markcz's Avatar
markcz
If you don't have onstar the C2R-GM24 is the adapter you need. That's the one I'm using in my '07.
FYI, the orange wires in the harness are useless, connect radio amp (or power antenna) remote output to blue wire in harness to power up oem antenna module (also powers oem amp if not removed).
The RCA plugs on the adapter are the inputs that go to the oem amp if you aren't doing new amp/speakers. Just ignore them if you are gutting the Bose parts.
Doors aren't sealed. If you want to add some soundproofing, Rick (RAAMaudio) sells some great stuff at even better prices.
Several places sell precut door speaker plates, or DIY with 1/4" MDF sheet from Home Depot.
Old Apr 14, 2011 | 10:48 PM
drivinfast's Avatar
drivinfast
I did not have onstar in my 06 and i believe the C2R-GM24 has the chime unit that is volume adjustable
Old Apr 14, 2011 | 11:05 PM
ROC OUT's Avatar
ROC OUT
Rick at RAAMAUDIO also makes adapters to add the 6.5" speakers in the doors. Get both the sound deadener and adapters from Rick and you won't be sorry.
To new to corvette
