Issues with OnStar, Z130BT and PAC OS2Bose
There isn't anything specific for a corvette. The 130 bypass is the same on a vette as it is on a Yugo.
All from here
The new 130BT does have a different A/V harness than the old.
Ground the brake, and move the mute wire up one in the harness, ground it, and its good to go! Did mine tonight and drove home with Netflix working fine.
It looks like the wiring harnes on the 130 is different than the one on the 120 and 110. Where exactly is the mute wire moved to? The positioning of this wire is on the bottom left row, second from the end.
O = Open spot, X = Mute wire, and w = other wires.
Here is a what the factory harness looks like:
oowwwwwwwwww
oXwwwwwwwwww
Found it on YouTube...
oowwwwwwwwww
oXwwwwwwwwww
St. Jude Donor '08-'09-'10-'11-'12-'13, '15,'21
Really, so you're saying that the wire colors are the same?? Like I said, I was looking for specific info, not general...
