Sponsored by: Innova
'78 C3 speaker help
Old Apr 23, 2011 | 11:03 PM
thinksnow's Avatar
thinksnow
Default '78 C3 speaker help
I am in the process of installing a stereo in my '78 C3.
What speakers should I run in the dash? Should I install some kick panel speakers? How about in the rear? I have a set of Rockford Fosgate 6 x 9 Twins. Should I even use them in the rear?
I have a sub box ready to go loaded with two 10's. The whole system will be powered by two Rockford Fosgate amps. A Power 500A2 will power the subs and a Punch 400A4 will power the rest of the system. I think that should be plenty power for a small car. If not, I also have a Power 1000DB ready to go.LOL
A big thanks to Rick from RAAM Audio for all the help with sound deadening. I can't believe how much more solid the doors sound. I haven't had a chance to drive the car yet because it is still in pieces. I bet the road noise is gone if it is anything like the doors. Anyone looking to get rid of road noise, get ahold of Rick and he can help.
Any help on the speakers would be greatly appreciated. I am unsure as to what speakers fit and which ones work in our cars.
Thanks,
Lance
Old Apr 24, 2011 | 11:40 PM
thinksnow's Avatar
thinksnow
Wow, 35+ views and no responses? PM me your ideas if you like. I need some help on what will fit and what won't fit. I need to get some speakers on order ASAP. I want my ride back on the road SOON.LOL
Old Apr 25, 2011 | 12:00 AM
mds3013's Avatar
mds3013
Polk Audio DB-651s in my '77.
My system here. mike...
http://forums.corvetteforum.com/c3-g...o-upgrade.html
Old Apr 25, 2011 | 06:58 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Not to "dis" you, but this subject was extensively discussed a couple of times within the last 5-6 weeks. You might want to do a search, or scroll back throught he threads.....
Old Apr 25, 2011 | 10:47 PM
thinksnow's Avatar
thinksnow
You are not "dis"ing me. I looked back about six or seven pages in this area and found a couple posts about C3's.
Are those Polk speakers shallow mounts or is there enough room behind those panels? This is my first Vette and I haven't taking those panels off as of yet. How much depth is behind the panels?
Thanks for the replies.
Old Apr 25, 2011 | 10:57 PM
mds3013's Avatar
mds3013
Mine are not the slims. These have the plastic ring mount included in the box that I glued to the kick panel to add some strength. The slims do not have the rings. I will provide you a link in a few minutes. mike...
http://forums.corvetteforum.com/c3-g...ion-guide.html
Also ck. link in post #4. This is where the procedure started. Thank you DB. Rest in peace. LOL...
Also install the pass. side speaker upside down. This provides clearance for the wiring terminals. Follow the directions in the first link exactly. It is really close but I made it work so I think just about anybody can. Post here or PM me if you have any questions. mike...
To '78 C3 speaker help
