Sponsored by: Innova
Door subs
Old May 16, 2011 | 12:34 AM
ReosLS2's Avatar
ReosLS2
Default Door subs
Hi
If your installing an Amp & Sub enclosure in the back of A C-6... What then are guys doing w/ the 10 inch door subwoofers, keeping them or swapping them out for midranges/tweeters and if that's the case can you just swap in the midranges/tweeters or do you need to change the powering---Thanx---
Old May 16, 2011 | 09:16 AM
markcz's Avatar
markcz
Many just add the sub and call it a day. You can also replace the 'twiddlers' in the doors with aftermarket 2-way 3.5" speakers for a bit better/clearer high end.
If you remove the door subs, most install a 6.5" component set with a new amp that's much more powerful than the stock one.
Old May 16, 2011 | 10:04 AM
ReosLS2's Avatar
ReosLS2
Default Beautiful
Beautiful thats what I needed to know...
Old May 20, 2011 | 10:14 AM
snoopdan's Avatar
snoopdan
I replaced my door speakers with 8" morel integras
To Door subs
