Sponsored by: Innova
newer iPODs and PAL
Old May 17, 2011 | 10:25 PM
tampatopless's Avatar
tampatopless
Default newer iPODs and PAL
Well, I guess Apple made good on their promise.
GM's PAL does not charge the newer versions of iPods. It's gotta have a USB connection.
GM PAL's owner manual, apparently written before 2008, talks about the possibility of later iPod versions not being able to be recharged with the 30-pin connection.
Ray, is it the same with your version?
I just can't believe Apple. That is WAY too proprietary.
Old May 18, 2011 | 02:16 AM
Thrillhouse's Avatar
Thrillhouse
You just need an adapter to convert the 12v charging line to the newer 5v standard. Something like this: http://www.amazon.com/Scosche-passPO...ref=pd_sim_e_1
It has nothing to do with apple trying to be proprietary, they just switched to charging from 5v over USB instead of 12v over firewire.
Old May 18, 2011 | 06:46 AM
tampatopless
Are both ends 30-point connectors? I mean everything with PAL fits, it just doesn't charge.
Old May 18, 2011 | 02:03 PM
Thrillhouse
it's just a little adapter that goes on the end of the cable from the PAL module. It has a 30 pin input and a 30 pin output, it converts the 12v charging line from the PAL to the 5v used by the newer devices.
Old May 18, 2011 | 08:55 PM
Dave O's Avatar
Dave O
When I had my PAL from Ray my new Ipod Touch charged just fine. I would contact Ray as I think the new Ipods should charge just fine.
Old May 18, 2011 | 09:15 PM
u1arunit's Avatar
u1arunit
Ray sells the cables that charge at the lower voltage on his site. I used one when I installed my PAL.
Lookie here: http://www.kawal.net/corvettemods.htm
Old May 19, 2011 | 07:54 AM
tampatopless
U guys are all correct. It is a 12V vs. a 5V issue and Ray's kit does include a 5V cord. I just need to get the adapter ($17) if I wanna use my iPod.
Right now, I'm using my kid's older iPod classic. Lotta music from groups with names like Dead Mouse, etc. Now I know how my parents felt when I played my music back in the day.
God, they must have hated it.
To newer iPODs and PAL
