Sponsored by: Innova
Wire routing
Old May 26, 2011 | 04:33 PM
ReosLS2's Avatar
ReosLS2
Default Wire routing
What's the best way to route wiring from the dash to Amp that will be located behind passenger seat and then on to sub enclosure in trunk.If I'm to run it down along door frame how do I get that long black plastic trim piece off or are you just stuffing the wire up there.Any other ways or ways of removing trim would help me alot.Thanx...
Old May 26, 2011 | 04:43 PM
Thrillhouse's Avatar
Thrillhouse
The trim just pops off. Take off the trim and carpet and you'll see a bundle of wires already running down the side of the car. Flip open the ties and run your cable next to everything else.
Old May 26, 2011 | 06:22 PM
ReosLS2's Avatar
ReosLS2
Just pops off.. Okay good, Thanx...
Old May 26, 2011 | 09:44 PM
markcz's Avatar
markcz
Start at the rear edge by the seatbelt anchor. Pull straight up until 3 or 4 clips let go, get trim piece to 30* or so, then pull towards rear of car to pop out one on vertical wall in front.
Old May 26, 2011 | 11:16 PM
ReosLS2's Avatar
ReosLS2
Alright beautiful..Thanx for the tip...
To Wire routing
