Sponsored by: Innova
Double Din Install w/Pics
Old Jun 2, 2011 | 11:39 PM
cheemsaf's Avatar
cheemsaf
Default Double Din Install w/Pics
Not done yet...but I will continue to document my progress via pics. Currently everything is removed and just waiting for the parts from Dennis's DoubleDin company out in WI. Can't wait! I currently have a stock radio system that's now over a decade old (1999 ) and am now putting in the following equipment:
Pioneer Z130
Elemental Design e5.10 sub in a pre-made sealed box
Kenwood XR5S Amp
Vibe Space 6s in the front
Polk db621s in the back
& the miles of wiring to go along with it
Wish me luck...
Old Jun 3, 2011 | 10:45 AM
ncvette_1FUNRIDE's Avatar
ncvette_1FUNRIDE
2015 C6 of the Year Finalist
Here's wishing you luck with your install. Hopefully it will work great the first time you turn it on.
I have to tackle all of that myself for my 2010 coupe sometime this fall when the weather gets cooler.
Old Jun 3, 2011 | 05:59 PM
markcz's Avatar
markcz
Originally Posted by cheemsaf
Currently everything is removed and just waiting for the parts....
Have you considered installing soundproofing in the car? Rick at RAAMaudio has a great deal for considerably under $200 shipped that will make the car soooo much quieter on the inside. PM him about his 1 box & 3 yards package
It's about time
Old Jun 17, 2011 | 09:17 PM
cheemsaf's Avatar
cheemsaf
Thanks, I've now placed all the wiring where it needs to go and am figuring out how to mount the Vibe Space 6s in the front.
They have 4 pieces...the woofer, mid, tweeter, and a crossover. I'm unsure where to mount the tweeter and crossover right now, and am doing some research on it. Anyone have suggestions??
I just got the Z130 to turn on with the amp for the first time on attempt number 2. Thanks Dennis for the help!!
I'll send out more pics once I get closer to finishing. It's turning into a marathon now with the install, couple of hours a night of figuring it out.
Old Jun 17, 2011 | 11:52 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
Space 6 in my car
crossovers are up under dash
Old Jun 18, 2011 | 12:29 PM
cheemsaf's Avatar
cheemsaf
Dennis, that looks very similar. I was planning on putting the crossovers in the door; I've already carved out a section in the styrofoam where they'll go; but I think under the dash looks like a cleaner install. I'll take a look. Where did you put your tweeters?
Old Jun 18, 2011 | 12:31 PM
0Double D Mods
Former Vendor
the mid is below the tweeters
they are stackable
so you can mount the tweeters on top of the mids
Old Jun 20, 2011 | 07:01 PM
cheemsaf's Avatar
cheemsaf
Well, I now have the 4 speakers working, the Z130 working, and the amp working. I just used the bose covers over the Vibes and Polks, which by the way sound tremendously better than those excuse of speakers that GM put in there. I should be receiving the sub and box tomorrow in the mail. Then it's just a matter of cleaning up the mess in the pictures below and fitting the Z130 into the middle frame. Any suggestions on removing the metal frame without removing the entire dash? I've attempted to pull it out, but it's not budging beyond about 4-5 inches of movement.
Mess of wires
More mess, but it works.
The amp, all alone...waiting for the sub & box to properly mount the amp. Some of those wires are left over from my N2O days. I think I'll leave the N2O lines/wires there in case I get the itch again.
I put the crossover in the styrofoam of the door. I think I'm going to remove it and place it under the dash. It's a very tight fit when placing the door facia back on.
Old Jun 20, 2011 | 10:34 PM
cheemsaf's Avatar
cheemsaf
And here is where I put the GPS antenna. It picked up the signal and relocated my nav system to my house in a few seconds while the hood was closed and inside the garage (garage door open) about 6 feet from the door.
This is a picture of where the battery normally sits. I ran the GPS antenna wire back through the firewall grommet with the other upteenbillion other N20 wires. You'll also notice I had to cut into the positive terminal rubber part to get the fastener for the amp to stay on the terminal. (Seriously Chevy, why do you have to make things so complicated??) Also, you'll notice I ran my amp positive/power wire to the driver side of the car (as the RCA cables run along the passenger side). The huge 4 gauge power cable goes through a hole I drilled on the driver side just below the hood release. I already drilled this hole for the Autometer gauges on the A-pillar I installed.
I put the phone mic here (below). I figured if you're going to be talking on the phone with the top off, you're probably going to be not "hands-free" anywhere you place the mic. It looks obvious in this picture, but you don't even notice it, unless you're looking for it with the black interior.
Old Jun 20, 2011 | 11:34 PM
markcz's Avatar
markcz
Old Jun 21, 2011 | 03:42 PM
okie08vette's Avatar
okie08vette
Default Fyi
I put my mic right above my right knee it just sits in the joint between the tunnel and center console, is not noticeable at all and works with the top off.
Old Jun 22, 2011 | 11:21 PM
cheemsaf's Avatar
cheemsaf
Thanks, I'll take a look at placing it there. I received the sub and box yesterday mounted it and am cleaning up the trunk area now.
WOW!!! Talk about some throw on that woofer. It was shaking my garage and got the neighbor's attention from across the street. But that was a good thing; he's into car audio as well. I'm going to have to tune the system here shortly so I still have some hearing left.
Old Jun 30, 2011 | 04:55 PM
1quick1's Avatar
1quick1
Looks good. I'll be following as I'll be doing a double din here in the future and will need to run the mic and GPS antenna as well. Everything else looks like a piece of cake.
Old Jul 3, 2011 | 03:26 PM
Chicago1's Avatar
Chicago1
No issues on the other end with callers? I am still debating where to put mine and I always have my top off.
Old Jul 8, 2011 | 04:09 PM
1quick1's Avatar
1quick1
Hows the install going? I'm just starting to tackle mine.
Old Jul 13, 2011 | 04:23 PM
Chicago1's Avatar
Chicago1
I had to cut the side tabs to fit my DD since the bezel has these 2 long tabs that stick out and needed to go into the holes where the brackets where. Did you have to do the same? I may put one in teh back but it seems pretty sturdy now.
Old Jul 13, 2011 | 05:53 PM
Chicago1's Avatar
Chicago1
No but I know other have said they just flip it over. Just a little more measuring that's what I'm going to do.
To Double Din Install w/Pics
Old Jul 13, 2011 | 06:25 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
i have installed a number of dbl dins in different cars and have never put a rear support in and have never had anyone come back with an issue
Old Aug 8, 2011 | 09:58 PM
20vette0107fatboy's Avatar
20vette0107fatboy
This is my next mod. The pioneer Z130. Hopefully I can do it. Im not doing speakers just the double din....
Old Aug 8, 2011 | 10:21 PM
0Double D Mods
Former Vendor
you will be fine
you have me ont he other end of the phone to help out
