I don't know what year your c4 is, but I found a wiring hole in the driver footwell that I could sneak wiring through. Pull the carpet back and look for a wide rubber grommet. I can't recall if there was already wiring there or not.
Don't get a cap, they are silly.
I doubt you'll need an alt upgrade.
'86. I think I know the grommet you're talking about. I figured that'd be the way since I'd probably burn out any smaller wires I hooked the larger 4g up.
Yeah, that's what I've heard about caps. I'm not running performance audio. I'll see how it runs before I look into an alt upgrade.
you will be fine... no need for an upgraded alternator or cap
Awesome, thanks for the input.
Just to followup, I couldn't find the grommet, at least one in the area I was hoping for. I ended up 'carefully' going through the firewall, above the foot well, not far from the battery, in an area unlikely to get any weather. The hole sealed up nicely—but will be something to watch for the summer. The wire runs tucked under the carpet near e-brake and into the hatch along the wall.
Drill bit was 7/16 with a smaller pilot hole.
I found 20' of 4-gauge wire leaves a little breathing room on both ends for final fit.
Hope that'll help anyone else looking to do the same!
