I have had my audio system installed and working great for some time. Yesterday, after an oil change, I notice that when I turn the radio on there is about a 30 second delay before my amp turns on. Anyone know why this should be occurring or why it started doing that all of a sudden.
I have a Pioneer 4300DVD head unit and a Kenwood XR5S amp.
Would you know which one is the remote wire? You mean from the power cable coming off the battery?
This problem also just started after the dealer turned on the "after blower" on the air conditioning cause I was getting musty smell from it. You don't think there is any relationship?
Amps use a 12V "trigger" wire to turn on & off - if volts are there they turn on, when the volts are gone they turn off. Almost all head units (except the very cheapest where an external amp isn't an issue) have a 12V+ amp trigger wire. The installer should have connected that wire to the 12v trigger input on your amp. The amp is way easier to get to so get out your volt meter, find the amp and hunt down the trigger wire and the amp's ground. Turn the car on and check for 12V on that wire. If it's there right away and the amp is delaying in turning on it's probably something in the amp. If there's a delay then you need to find out where the trigger is. If the amp is triggering off your fuse box then what the dealer did *may* have changed it.
Any chance it only happens when you're listening to an ipod controlled by the HU? On rare occasions my HU will take a few minutes to recognize the ipod is there, then eventually start playing music after 30-60 seconds. If that's what you were listening to when you turned the car off/on it may just look like the amp isn't turning on.
Mark, it is happening everytime. I need to check the trigger wire. What I don't understand is if no power is getting through the trigger wire to turn on the amp, then how come after the HU is on for about 30 seconds, the amp does come on?
This is probably unrelated but it only started after my oil change and having the dealer turn on the air conditioning after blower. Another thing that just started is that the car chime goes off after I start the car (about 20 seconds after starting the car) and then every so often it may go off. I thought it was signalling an error message or car problem but nothing is displayed on the dash. Odd.
You gots an electrical gremlin running loose in there.... Or a programming gremlin depending on what the dealer did. I would report that symptom to the dealer because smoke & fire, odds are they're related.
It could be the ground wire, but it seems odd that it would only act up on startup.
With the car off, put a DC meter on the trigger and amp ground. Turn on the car and watch the meter right next to the HU. The meter should show 12v almost immediately after the HU powers up. If it does, but the amp doesn't power up, the problem is with the amp.
It was the Metra adapter unit. The HU was sending out the trigger voltage but it was not getting through the adapter. We just bypassed the adapter and connected the HU trigger wire directly to the amp. All is fine now.
