Sponsored by: Innova
C4 speaker mount spots suggestions / help
Old Jun 22, 2011 | 09:31 AM
LD85's Avatar
LD85
Default C4 speaker mount spots suggestions / help
I have two 8" subs in the rear openings and two 6.5" compoennets speakers in the doors.
There is not enough sound coming from the 6.5 door speakers.
Where can I mount another set of speakers in the car?
Old Jun 22, 2011 | 10:36 AM
Kale's Avatar
Kale
Hold on, before you start adding speakers and making your system sound worse, let's figure out what's going on with your 6.5s.
What brand/model are they? What type of amp is powering them?
Old Jun 22, 2011 | 10:52 AM
LD85's Avatar
LD85
Rear
Two 2-8" JBL subs with 2 x 150 watt amp
Front
Focal 165V1 with Phoenix Gold 2x75
Old Jun 22, 2011 | 11:48 AM
Kale's Avatar
Kale
Focal 165vs should be loud enough to hurt pretty bad at 75% volume. Though maybe th ePG amp is overrated? Are you not hearing them over the road noise, or are you looking to hear them with the top off?
Old Jun 22, 2011 | 12:52 PM
LD85's Avatar
LD85
You are right Kale , I think the PG is indeed underrated...
I just swapped in my 2x150 watt Jensen amp and even though the Jensen amp is not that great, it sounded better immediately.
Also, my 406ci engine is pretty rumbly,, so I just want the sound to be more clear without driving them pretty hard.
Old Jun 22, 2011 | 01:56 PM
Kale's Avatar
Kale
When I had my focals in my 86 they were pretty much at high levels the whole time. (100wx2) The combination of more power and sound deadening should make things a LOT better.
If you just want volume, I'd throw a pair of 6x9s on the back wall in boxes. The bass won't be great, but they add a ton of noise. It's going to mess up the sound quality and sound stage, but it wil be a lot louder.
Old Jun 23, 2011 | 08:13 AM
LD85's Avatar
LD85
Kale, thanks a million!
I took my Jensen 150 x2 amp and connected it to the Focals and the sound improved noticeablly
Than I took my 2x75 Phoenix Gold amp and set it up bridged to run the two 8" subs at 1x250 watts bridged.
the subs have more punch and are more crisp and the over sound is much better than it was before.... I was beginning to hate the two 8's in the rear but with more power they do a great job.
Thanks for preventing form buying new stuff and helping me to set up the components I have better!
I wouldn't mind adding another amp and putting a set of speakers in my dash holes but I don't know what I would put there because they have to be thin/flat,,, or maybe just tweeters
I could use the door speakers for mid range only maybe
Old Jun 23, 2011 | 11:06 AM
Kale's Avatar
Kale
Any time!
When I first started tinkering, I put 4x6s up in the top spots. They really didn't contribute to the sound - just made everything sound really tinny.
Tweeters might work up there - you would have to try it. Might sound too harsh, but it might work out nicely.
Old Jun 23, 2011 | 02:52 PM
LD85's Avatar
LD85
I like the way it sounds a lot right now, I just need to figure out the best settings for my Eclipse receiver CD4000
Old Jun 23, 2011 | 06:18 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Larry,
Check out this link, it shows how to make pods for the tweeters that will raise the sound stage in the car, really improves the sound.
Randy
http://www.diymobileaudio.com/forum/...eter-pods.html
Old Jun 23, 2011 | 07:58 PM
LD85's Avatar
LD85
Originally Posted by RandyJ75
Larry,
Randy
wow , there's some creative guys on that site
To C4 speaker mount spots suggestions / help
