Sponsored by: Innova
Amp crunch
Old Jul 2, 2011 | 06:35 PM
wagner262's Avatar
wagner262
Default Amp crunch
I bought a amp crunch 4 way 900 watt a couple months finally go finally got around to installing. I hooked it up to my 10 ' subs worked for a couple day probably a total of 2 hours maybe of play. One day it didn't work. Blown fuses so I went Into the shop and asked for new fuses. The guy in the shop came out and tested it and told me my sub is blown. It was brand new working fine a week ago. I guess I'm trying to figure out if he's pulling my leg to get me to buy from his shop or my brand new amp just died on me. I'm a new to this stuff buy I just can't believe this!
Old Jul 2, 2011 | 07:09 PM
Kale's Avatar
Kale
Well, crunch amps are ****. Sorry.
You can check the subs with a voltmeter. Check ohms. Should read somewhere in the neighborhood of what it's rated at.
Fuses don't just blow for ***** and grins. You could have been running it way too hard, clipping the **** out of it, it could have an internal short, maybe the sub shorted... who knows?
Can't hurt to get a second opinion.
Old Jul 2, 2011 | 07:20 PM
GKK's Avatar
GKK
How are the sub's wired (parallel or in series) and are the subs 2, 4 or 8 ohms also, what is the amps rated RMS output?
Old Jul 2, 2011 | 08:42 PM
wagner262's Avatar
wagner262
theres power to the amp. i wasnt pushing it as i was trying to break it in. im pretty sure they are wired parallel. im new at this so sorry if im slow.. ill try and check ohms and get a second opinion.
my amp is a pzt900.4 crunch and my subs are kenwood kfc-w2512
Old Jul 2, 2011 | 10:20 PM
GKK's Avatar
GKK
If the subs are wired in parallel, most amps bridged are rated at 4 ohms (that's two 8 ohm subs wired in parallel).
If two 4 ohm subs are wired in parallel, the amp will see a 2 ohm load and run much hotter which can cause problems on an inferior amp.
You have to find out what Ohms the subs are rated (look on the magnet) and how they are wired.
To Amp crunch
