Sponsored by: Innova
C6 sub install, issues
Old Jul 12, 2011 | 12:30 AM
Tikiman12's Avatar
Tikiman12
Default C6 sub install, issues
Hello,
I've finially got my sound system installed and working.
my issues are:
1. the remote wire keeps the amp on even after the ignition is off and after the door has been closed and locked. (I spliced into the white wire from the rear of the head unit I believe its wire B3)
2. I'm hearing a LOUD whistle in the rear speakers (the ones I spliced) from the RPMs of the engine.
As for the whistle I'm sure i'm just hearing the rpm ohms from the engine b/c of how I spliced or layed the wires. I used an extra set of RCA female wires and spliced right into the wires that lead off of the head unit. How can I prevent the whistle?
Thank you
Old Jul 12, 2011 | 11:35 AM
Tikiman12's Avatar
Tikiman12
bump
Old Jul 12, 2011 | 11:55 AM
Icetech's Avatar
Icetech
wait a few mins and the amp will go off.. it stays on til the interior lights and all that go off.. no big thing...
As far as the whine.. bout 100 posts cover using gli's... you did use gli's? or grounded the rca's?
Old Jul 12, 2011 | 12:35 PM
Tikiman12's Avatar
Tikiman12
but I left the car for 2 hours, went back to check on it and it was still on.
The car was locked all lights off and everything.
It wouldnt turn back on just form the trunk being opened would it?
Old Jul 12, 2011 | 01:29 PM
Icetech's Avatar
Icetech
yes... close the car up... leave the fob in the house.. when you see the interior lights turn off the amp should turn off... trunk open=interior lights on
Old Jul 12, 2011 | 02:06 PM
Tikiman12's Avatar
Tikiman12
k. I'll try to check that.
now for the ground loop isolators, can I just attach a wire to my RCA connections and then attach it with a screw to the back of the headunit?
Old Jul 12, 2011 | 04:41 PM
markcz's Avatar
markcz
GLI's are these.
For the power on/off issues, you can use the wiper fuse to trigger the amp initially (when the car is started), then use B3 to keep it powered until a door is opened if you wire up 2 diodes and a relay like this:
To C6 sub install, issues
