Sponsored by: Innova
C6 Coupe Sub Boxes! only $79.99!
Old Jul 16, 2011 | 11:31 AM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
Default C6 Coupe Sub Boxes! only $79.99!
I have 50 more of these coming in late next week!
Will fit COUPE only!
Vert and Z boxes are in the works
$79.99
click here to order yours!
We designed these ourselves at ATREND in Chicago!
Atrend makes these for us along with all our custom vehicle specific boxes.
Box is designed to allow for the top to fit exactly as it would with no box!
terminals on backside of box allows for easy in and out should you need more room or to save weight at track day!
Optional!
Get these preloaded with 2 Kicker CVT subs!
Only $179.99 extra!
Pic of box installed with optional Kicker subs!
Box will come in gray carpet
2- 10" cutouts
mounting depth of 4 3/4 inches with no top ring. Add the option for matching carpet rings($10.00) to increase the mounting depth to 5 1/2 inches.
air space of 1.21 cu ft
speaker terminals on back side of box included
Old Jul 16, 2011 | 12:15 PM
kedar's Avatar
kedar
St. Jude Donor '12
That is an awesome price! I am waiting for an attractive box with a good sub that only takes up one corner of the C6 coupe and allows for stowage of the targe top.
Old Jul 16, 2011 | 12:21 PM
0Double D Mods
Former Vendor
I am working on the C5 corner boxes now and then will move on to the the C6
Just not enough time in the day
Old Jul 20, 2011 | 06:05 AM
Mister Peebody's Avatar
Mister Peebody
From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
What about a fitted C6 vert box?
Old Jul 20, 2011 | 07:23 AM
0Double D Mods
Former Vendor
We are working on them.
The back wall is different on a Vert and Z so this box will not fit
Old Nov 1, 2011 | 05:08 AM
jon6.0's Avatar
jon6.0
With the trim rings and increased mounting depth, can you still fit the top? What are some other sub options? I've got a JL Audio 500/1 to power the subs and a 300/4 for the door speakers. Where would you recommend mounting the amps? I was thinking one behind each seat would be easiest.
Old Nov 1, 2011 | 05:24 AM
jon6.0's Avatar
jon6.0
The Kicker manual on those CVT subs is calling for .8 ft3 per speaker. Since your box is 1.21 ft3 are you filling them with poly fill?
Old Nov 1, 2011 | 03:13 PM
Fasthotrod's Avatar
Fasthotrod
Poly fill gives the sub the impression of an even bigger box... quite the opposite of what you are trying to accomplish in that case.
Thankfully, Kicker recommends an enclosure that is between 0.8 - 3.0 ft^3 for the CVT's, and using poly fill is a good idea to help cut down on reflections, so you'll be good to go.
Old Nov 1, 2011 | 04:44 PM
markcz's Avatar
markcz
If you need to make a pre-made box have a smaller volume you can always attach a piece of 2x4 in the bottom corner
Old Nov 1, 2011 | 04:52 PM
b.lee's Avatar
b.lee
Looks nice, great price
He ships fast too!
Old Nov 1, 2011 | 07:09 PM
DRLC5's Avatar
DRLC5
PM Sent
To C6 Coupe Sub Boxes! only $79.99!
