Sponsored by: Innova
Amp power wire gauge question
Old Aug 26, 2011 | 02:17 PM
VetteNoob's Avatar
VetteNoob
Default Amp power wire gauge question
The amp calls for 4 ga power and ground.
If I run the 4 ga power from the battery terminal to a dist block <2ft from the amp and run the 4 ga ground to a dist block <2ft from the amp, can I run 8 ga off the dist blocks to the amp without negative effects?
Old Aug 26, 2011 | 03:35 PM
EVRose's Avatar
EVRose
I've done that before without any negative effects. How many watts is your amp?
Old Aug 26, 2011 | 03:40 PM
VetteNoob's Avatar
VetteNoob
It's the PowerBass ASA 600.4x.
http://www.powerbassusa.com/asa-6004x-4-ch-amplifier
Old Aug 26, 2011 | 04:34 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
wont be a problem... hell 8ga would probally support that amp
Old Aug 26, 2011 | 04:40 PM
VetteNoob's Avatar
VetteNoob
Cool. If I eventually go with a dedicated sub amp, the setup should be ok?
Old Aug 26, 2011 | 05:10 PM
EVRose's Avatar
EVRose
I couldn't remember what gauge I used so I just checked and I have the same setup. 4ga from battery to dist. block and 8 ga to 2 separate amps. It's only about 8" from the block to the amps but you shouldn't have any problems with 2'.
Old Aug 26, 2011 | 07:21 PM
Kale's Avatar
Kale
Be sure to add a fuse when downsizing wire. (positive side)
Old Aug 26, 2011 | 07:41 PM
VetteNoob's Avatar
VetteNoob
Does a fuse for each lead at the dist block count?
Old Aug 26, 2011 | 08:57 PM
Kale's Avatar
Kale
fused distro block is good yes.
Old Aug 28, 2011 | 08:23 PM
kedar's Avatar
kedar
St. Jude Donor '12
i have four gauge power wire (60 amp ANL fuse w/in 18 inches of battery), which i would like to run to a distribution block and then run two 8 gauge wires to two amps (ARC ks500.1 mini and ks125.4 mini).
1) am i understanding it correctly that i should have a fuse between the distribution block and the amps?
2) is it better to use a fused distribution block?
3) most importantly, what amp rating should each fuse have?
Old Aug 28, 2011 | 09:35 PM
pentavolvo's Avatar
pentavolvo
you should use a fused distro block but with that said i have done it many times without fusing. a fused distro block is easier then a regular distro block then a fuse holder
50amp should be plenty
Old Aug 28, 2011 | 09:44 PM
Kale's Avatar
Kale
Fused distro block, yes. If you don't use a fuse, the wire becomes the fuse. This is how fires start.
Depends on gauge and distance. You fuse for the wire, not for the equipment.
http://www.bcae1.com/images/swfs/sys...nassistant.swf
This will do it all for you.
Old Aug 28, 2011 | 10:09 PM
VetteNoob's Avatar
VetteNoob
That link says I should run 4 ga wires and an 80amp fuse on the dist block for my Powerbass 600.4x (800 rms). So will the 8 ga wires still be ok? Also, I was planning on running a 60 amp fuse at the dist block. Am I still good?
Old Aug 29, 2011 | 12:15 AM
pentavolvo's Avatar
pentavolvo
amp is fused at 60amps and it wont even draw that much. a 50 or 60 in distro will be plenty
Old Aug 29, 2011 | 11:10 AM
VetteNoob's Avatar
VetteNoob
To Amp power wire gauge question
