Sponsored by: Innova
AMP won't power up...HELP?
Old Sep 5, 2011 | 02:13 PM
twofeet020's Avatar
twofeet020
Originally Posted by pentavolvo
yes deffinetly change ground, you probally have huge voltage drop which could explain your heat issue
once i change the ground wire to the correct 4 gauge wire, should this also improve the quality of the bass i.e.-bass hitting harder?
Old Sep 5, 2011 | 02:14 PM
WAwatchnut's Avatar
WAwatchnut
The gauge of the wire was one of my first thoughts, but going by the picture, are you sure that that's 14ga wire? Looks a lot bigger.
In the coupe there's a ground point in the base of the pillar behind the passenger side. Grounding there is good if you sand the paint under the screw. Not sure about the location you're using... Haven't worked on a vert.
It may help the bass a little, but shouldn't make much of a difference.
Old Sep 5, 2011 | 02:22 PM
twofeet020's Avatar
twofeet020
The AMP kit i got came with a power and ground cable of 4 gauge but the ground one was to short. The ground wire i have on there now is 14 gauge. Too small. So i have ordered a longer 4 gauge wire for the ground.
Old Sep 5, 2011 | 02:51 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
deff would make a big difference
Old Sep 8, 2011 | 11:46 PM
twofeet020's Avatar
twofeet020
i changed out the 14 gauge ground wire now to the correct 4 gauge wire but the amp still gets ridiculously hot. perhaps where i have it grounded needs to be slightly sanded...maybe ill try one of the seat bolts too and see how that does
