Full Audio Upgrade Planning ...
I am almost all set to do my mega-install on my '09 vert, so thought I'd share the planning portion while waiting for a few parts & before photoing the install. I attached PDFs if those help with your planning.
I'll keep the ugly 2LT non-bose HU and start with a full deadening, pillar tweets, all new speakers, amps and processor. More to come ...
Thanks for the comments, that's what I need. The acoustic stage was a major focus, 4-pairs of tweeters are in there, 6 midranges and the sub. I'll be able to change to xover and gain on each pair of spkrs from the DQXS, using either the wired or wireless remote, as well as saving those settings on memory pre-sets. You need to check out that DQXS, an amazing device ...
But since you are serious- why not look at good DIY speakers like Seas, Scanspeak, even Tymphany?
I'm not a pro so I'm just asking, not sure if I'm right or not. If you hook up a $800 crossover to a clock radio, is it going to make beautiful sound? I'm just trying to wrap my head around how this will work. If the original source unit is not fantastic, can you make it better by hooking something up inbetween?
If I only have a VHS player and decide to hook it up to a brand new 1080p LED tv it's not going to look any better than on a 720p tv. Regardless of what I have on the output end the source is still an old analog junk box.
Also, if you're actually that concerned about SQ the imaging issues with 2938723 speakers is going to be quite a mess to play with. Not saying it can't be done, I'm just saying it can be done much easier, with less wiring, less install time, and less overall p.i.t.a.ness with less speakers.
Good point, but the stock speakers are all set below your chest (and ears) thus the stage is on the floor, whereas adding the pillar tweets and upper-door mid-range 3.5"s will (or should) raise those high & mid stages dramatically. I could see the rears not being used though, but have liked that fill in the past.
I'm with ya on the rears. Even though you don't necessarily need them I've kind of been a more=louder=better kind of guy
it's in the back behind the partition -and behind the top when it's down. So I'll see how that does and maybe make a switch if the bass is way down.
Your signal can only be as good as your source .. and unless you are listening to SACD or some other HIGH quality recording, cleaning and recleaning can only do so much.
At the end of the day, it's your dollars, and your ears. Maybe the theoretical 10% improvement in sound quality and performance that you would get from say Seas over Pyle is not worth it to you, or you may not "hear" the differences.
However, there is a level of "get what you pay for" involved in audio, on a SERIOUSLY sharply sliding scale of diminishing returns and escalating costs.
You are effectively comparing Sears Roadhandlers to Michelin PS2's and saying they are the "same". Sure they are both tires, but they do not handle, wear, perform anywhere close to "the same".
Your weak link in the system is your drivers, and it's not close. Followed behind by a full component set in the rear, but that is a whole different discussion.
Hats off for the schematic, and make sure you do some sound deadening.
G'luck
Fej
you got alot going on there.
